Downloading Snipping Tool For Windows 7 Home Basic
I am having an issue in taking a snapshot of the images and texts on computer. How can I download snipping tool for windows 7 home basic?
– You can easily take a partial or a complete cropped or an uncropped snapshot of your computer display whether it is a text or an image. It is done by using the snipping tool, usually it’s there factory installed in your computer but here is the solution if you have lost it.
You can download it from: – http://www.gutmannsoft.com/en/screenshot/capture-screenshot-lite.php
After downloading follow the steps:-
1. Install capture screenshot from the download link above.
2. Capture lite starts with Windows.
3. Double click the icon in your system tray or press the Print screen on your keyboard to take a screenshot.
4. Copy the screenshot into your clipboard. and/or
5. Save the screenshot in as BMP, JPG or PNG
