Dr Fix it in my Microsoft office 2010,does not help
I used Dr. fix it and now I have windows and can't be resized which makes it hard to read, how can I restore the previous settings to original state? Please assist
Do you mean the application window cannot be resized?
1.      Relook into the Dr fix it. There are options to rollback.
2.      Else you must have created a restore point before applying the Dr fix it. Restore the computer to an earlier state using system restore found in start to programs to accessories to system restore.
3.      Use windows update that will copy new files that will update the O S.
4.      Use repair the installation using the disk provided for the O S.
5.      Right click on the title bar and it has options to Size. Click this and you can size the window.
