Dr web anti virus against the trojan hunter
I had recently decided Dr web antivirus as my program for anti-virus.
Hello Sujan,
Dr. Web is an above average anti-virus. While being simple to use and something which requires no installation it can be helpful in situations when your PC is already infected.
I have always been a proponent of layered security and have been against maintaining multiple anti-virus software.
You may consider switching to KAV or RAV or Avast anti-virus, but my suggestion would be installing an anti-spyware/malware software as well, I have found Malware bytes to be good with a decent detection rate.
This way you are not relying on one software for protection and the approach also provides a better sense of security.
Hope this helps.
Mclean Buono
Notifications
