Dragon Naturally Speaking preferred and Dragon Naturally Speaking professional?
What is the main difference between Dragon Naturally Speaking preferred and Dragon Naturally Speaking professional?
Hi Cruz D Hatchell
Dragon Naturally Speaking is speech recognition software and it is developed by Nuance. The latest version is 11.5 and it supports Win XP, Vista & 7.
The Dragon naturally speaking preferred is the version for the home use while professional is for corporation use. There are some major differences between them, some o them are explained below.
Dragon Preferred |
Dragon Professional |
It don’t support Microsoft outlook, power point, Info Path |
It fully supports Microsoft Outlook, Power point, Info path |
There is no option of voice notation. |
It has voice notation option, with which user can make side comments which don’t appear in dictated text. |
There is no support for cordless microphones |
It fully allows the use of cordless microphones |
Micros cannot be created or shard ( Micros are short cuts which help you to speed up your task) |
Micros can be created and shared. Â |
Vocabulary option is available but it don’t allow customized vocabulary |
Vocabulary can be fully customized by adding new words. |
I don’t allow the saving of your recordings. |
You can save your recordings for their use later on |
It is not operable in Citrix environment |
It can be used in Citrix environment. |
 By reading this, I hope now you can choose Dragon according to your requirement.
