Toasty Guru
Posted on - 07/26/2016
I have heard about the text to speech feature of Dragon naturally speaking, but do not know how it works. I have dragon installed already. Can someone please explain how to make the dragon naturally speaking text to speech work?
Dragon Naturally Speaking Text To Speech: How To Make It Work?
Using dragon, it is very easy to use the text to speech feature. If you have dragon installed properly and are using Windows with version 64 bit, then you do not need to do much more. Just open control panel and check that your audio and speaker are enabled and at high volume.
Then, copy the text you want and paste it inside the dragon pad. After pasting, say “Read that” and now you can hear it in computer voice. If you do not want to paste text into the dragon pad, you can use it directly from recognized programs, such as Corel WordPerfect and microsoft word.
For this, you need to select the required text, go to the advanced menu(found in the menu bar) and click on “read that”.
