Draw Something Won’t Install on Android Phone
I’ve tried several times installing draw something on my Samsung Galaxy Y.
But the process is always failed. I don’t have any problems installing other apps, just this particular one.
How can I solve this?
Best Answer by Maybt Barton
Answered By 0 points N/A #142943
Have you checked if Draw Something is compatible with Samsung Galaxy Y?
Because I believe that the Draw Something is not yet available for Samsung Galaxy Y.
There a lot of updates and maybe it will be available soon.
You might want to try the Sketch and Draw Something instead.
Answered By 0 points N/A #142944
Good day Bertha,
Samsung galaxy Y is an android phone and "Draw Something" is a guessing game through drawing for android phones, but doesn't mean it can be compatible to all androids for however reason Samsung Galaxy Y hardware can't cope up to the software's specification requirements. but there are some version of "Draw Something" that will run to Samsung Galaxy Y however it is a bit laggy and sometimes you will see black squares in your screen. To sum it up, Samsung Galaxy Y's hardware specification is the reason why "Draw Something" will not launch in your phone.
Hope I helped you!
Take care!
