Draytek Vigor 2850n Router revealed
Hi, I want to upgrade my router with Draytek Vigor 2850n. Can I use Draytek Vigor 2850n as my access point  for my old router?
Let’s know about the router you mentioned, it works on the 802.11n Wi-Fi signal, which is the best mode to transfer data between two electronic devices connected through a computer network. The N-series of Wi-Fi signal works on the 40 MHz frequency band which enables it reach speeds of 300 Megabits per second which equals to a lot. One more thing to be noted is, it is backward compatible with the older versions of Wi-Fi hence your old electronics won’t be affected. On a whole, it is a great buy and with a great range. Make sure you take the right product, if you have a Wi-Fi card that works on 802.11a you might have problems, so check before you buy.
