Dreamweaver asp column sort, need your help on this one
Hi guys, I am into dreamweaver. Can you teach me how to create a dreamweaver asp column sort. Thanks guys. I badly need you help on this
I have created associate ASP: DataGrid and wish to permit guests to kind the DataGrid by clicking the desired column. I even have been fidgeting with completely different strategies however haven't found the answer by now.
Here is that the code that I even have on now. From what I even have scanned I felt I would like facilitate with the On Sort Sub I created (this is wherever I keep obtaining errors). I even have equipped the code below. The On Sort Sub code has been modified to permit the page to show however will nothing at now because the committal to writing I even have done produces errors.
As with my other server behaviors, the Sort Repeat Region server behavior is designed to work hand-in-hand with existing Dreamweaver server behaviors, like the Recordset and the Repeat Region. This server behavior will enhance the core set of Dreamweaver MX server behaviors by adding a Sort function to arsenal. The server behavior assumes you are using standard UltraDev or Dreamweaver MX recordsets and repeat regions. When you apply a repeat region to a table row, there is no easy way to sort the results according to the column heading. This server behavior can be applied to a table that has a repeat region on it. The server behavior will automatically create all the code necessary to have clickable links in place of the column headings that will order the recordset by that column. Another click will order in descending order.
