Hi there,
Suddenly this error appeared in the middle of the project. I can’t pass this error message and also I don’t know how to solve it. I saved my project and loaded it again and the same error appeared again. Can anyone help me please to fix this one ? What is causing this ?
Thank you !
Dreamweaver
The document’s current encoding cannot correctly save all of the characters within the document. You may want to change to UTF-8 or an encoding that supports the special characters in this document.
points
Dreamweaver error decoding the saved files
Encoding means the writing method of a file. There are many encoding methods available but UTF-8 is the best for its compatibility and large collection of syntaxes and characters.
To change the option to save in UTF-8,
1. Open the file for modifying in Dreamweaver.
2. Go to Modify >> Page Properties >> Title/Encoding.
3. Change encoding method to UTF-8 via the “Encoding DD”.
You can also use any text editor like Notepad, Notepad++ etc. Open the PHP file into the editor, select File >> Save As. Choose the “Encoding” to UTF-8.
