Dreamweaver error when loading shockwave object name
Hello there,
Sometimes when I’m working in Dreamweaver this error appear. I select the right object but it seems like is not working. I don’t know how to fix this or what is causing this. Does anyone have any idea about this error ? What is causing this one ?
Thank you !
Please select a shockwave object name or click Cancel.
The action will not be added to your document.
OK
Answered By points N/A #178049
It sounds like you’ve forgotten to upload something in the server so this error is appearing.
Your action that was created using Adobe Flash created two files; one main file and another supporting file. Most definitely, you’ve forgotten to upload both of the files. You only uploaded the main file which is unable to function properly without the supporting file.
Upload both files into server and then run again. This should go fine as expected.
