Dreamweaver shows error on Windows 7 Operating System 64bit
I am using Windows 7 Operating System 64bit and working on a project using Dreamweaver but today I got an error message when I attempted to start the program. I could not understand the cause of this error so need your assistance to fix this problem. Thanks in advance.
Dreamweaver
The following translators were not loaded due to error.
ICERegion.htm: has configuration information that is invalid.
JQueryMobile.htm: has configuration information that is invalid.
XSlTransform.htm:has configuration information that is invalid.
Answered By 5 points N/A #167334
This is a problem could occur after recent updates and could be by following the steps narrated below:
To solve the problem, ensure you close Dreamweaver CS4 and navigate to the drive c:
C:Documents and Settings [Username] Application DataAdobeDreamweaver CS4 [Language] Configuration.  While in the configuration folder, locate WinFileCache-[digits].dat and rename it to WinFileCache-[digits]-old.dat and start Dreamweaver again.
