Driver ati Toshiba not working
I've downloaded gfx drivers for my Toshiba L205 notebook with ATI 3000 graphics card. But on installation it says that I should notify Toshiba, because my drivers are incompatible with my notebook!
Hi Hollis,
I will certainly help you to solve your problem. Your Toshiba laptop uses ATI graphics card. You need to download the appropriate graphics card driver from the Toshiba website. You just cannot download from web and install it. Every PC manufacturer provide their own solution.
Go to Toshiba support website and choose your model and download the driver.
It will work.
Hey Riley, Hello there.
So you need to download some of the drivers for your notebook, you can always go to the official website, here you can select what type of device, series etc.
But in above link you can just insert the model number and get your required drivers and filter according to your requirement like Operating system etc.
Regards Ian M Tyner.
