King Lopezs
30 points
Posted on - 10/05/2012
I need driver for Dell webcam for win 7 download site. My laptop is Inspiron. My webcam is working except in YM and Skype. I checked Dell's website but my laptops model is not there. I've been searching for days but no luck. I can’t still find the correct driver.
Driver for Dell webcam for win 7 download
Go to this link and then click the link Create a Dell My Account.
Enter your data and click Create Account. You will be directed to your new account in Dell.
Click the "My Account" link and then scroll down to My Software.
Click the Download Factory Installed Software (My Dell Downloads).
Follow the on-screen instructions to install your pre-installed software for your Dell laptop.
Hi King,
You can download the webcam driver straight from Dell’s support site. Dell has different Inspiron models so you need to know exactly what model your computer is or you can take a look at the service tag number located at the bottom part of your laptop if in case you don’t know your model number. Below is the link where you can download the driver for your Dell Inspiron laptop. Just choose which Inspiron model you have and from there you’ll see the available drivers.
Dell Drivers and Downloads
Hope this helps you.
