Driver initialization failed. DCM status code- 0x844004415
Asked By 5 points N/A Posted on -
Hi there,
My Nokia Lumia phone started to have errors and a big lag. So I thought it would be good if I will run the recovery mode from Nokia Suite. During the process this error stopped the process and broke my phone. My phone is not starting anymore and I don’t know what to do. Can anyone help me please to solve this ? How can I repair my phone ?
Thank you !
Recovery
Recovery failed.
DTL.Connection. Could not connect to media DTL.Back-End error code- 0x840044035 DLT Back-End Driver initialization failed. DCM status code- 0x844004415. Common USB DCM. No device found from the target USB port. Last error code:0x801000010.
Copy to clipboard.
OK
Answered By 590495 points N/A #183717
If your handset no longer starts, open the back cover and disconnect the battery for about 10 minutes. It should be up and running afterwards. After 10 minutes connect the battery and close the back cover. Start your phone and it should open normally again. Check your handset if it behaves unusually after what you did.
Should you notice any odd behavior on your Smartphone, don’t recover your phone with the Nokia Suite using a specific package because it might extend the damage on your phone. Try restoring your phone using the factory settings which can be found on the phone. It should reset your handset to its factory settings and should have the default settings back.
Just configure your phone again after the restoration. If your application’s version is older than version 5, you should upgrade to Nokia Care Suite 5.0. It supports Windows XP, Windows Vista, and Windows 7.
