Abbram
20 points
Posted on - 01/12/2012
Hi All,
Not long ago I obtained this particular Dell Inspiron n5110, Intel Primary i5-2410M processor chip (2.3GHz, 3MB cache, 2.9GHz Turbo Boost), specifically with regard to video gaming as well as I'm trapped actually prior to I possibly could begin.
This states which my personal PROCESSOR might function @ 2.9GHz, in the event that it's needed along with Turbo boosting simply because it's a good i5 things, good…… After that how come this display a mistake Information after I 'm attempting to set up this particular Dell Software program inch Intel Turbo Increase Technologies Keep track of Software program 2.0" Driver ID R292474.EXE… for windows 7, 64 bit.
But it shows me an error message below:
Installation cannot continue because this computer does not have a processor with Intel Boost Technology capability.
This application requires an Intel Core(TM) i7 processor, Intel Core i7 processor Extreme Edition, or Intel Core i5 processor with Intel Turbo Boost Technology. For more information, see https://www.intel.com/content/www/us/en/architecture-and-technology/turbo-boost/turbo-boost-technology.html.
Therefore, my query is actually does it imply my System Doesn't Assistance Turbo Boosting Technologies?? Please reply.
Thank you !
Abbram
Lee Seen
Driver Installation Problems and Hardware Questions
There is a component that is missing on your computer that is required for the device driver to install successfully. As mentioned in the error message the lacking component is Intel Turbo boost technology capability processor. And therefore what you will need to do is look for that mentioned processor and install it to your system.
You may need to purchase it. But if you find it hard to get the processor, then you will just need to look for a device driver that can work with the processor that you currently have on your computer. You will need to check the system specifications and use them to search for the right driver online.
-Lee Seen
It only verifies that the processor on your computer doesn’t support the Turbo Boost Technology or doesn’t have Turbo Boost. To verify if your processor indeed supports Turbo Boost, download CPU-Z and install. It will help you verify if your processor really supports Turbo Boost. It installs on any version of Microsoft Windows.
To check the full specifications of your processor, go to Intel Core i5-2410M Processor. This processor is designed for laptops and was launched on the first quarter of 2011. Genuine Intel Core i5-2410M processors support Turbo Boost Technology 2.0. If the application you installed cannot detect Turbo Boost on your processor, it is possible that the processor is damaged or not functioning correctly.
Other features supported by the processor include:
- 64-bit support
- Hyper-Threading
- Virtualization
- Intel My WiFi technology
- 4G WiMAX Wireless technology
- Thermal monitoring technologies
