DRIVER _IRQL_ NOT_ LESS_ OR_ EQUAL error
Windows 7 error. Windows stop DRIVER_IRQL_NOT_LESS_OR_EQUAL error.
Please help to Solve this issue.
 Last, restart your computer. Hope this helps.
If this is the first time that this happens, try restarting your computer then try it again. See what happens after rebooting the system. If the problem still exists on the next reboot, try checking your computer for any possible errors. Use a disk utility application to check the system. For a much thorough diagnostic test on your computer, use disk utility applications like Norton SystemWorks, Norton Utilities, or PC Tools Performance Toolkit.
If this problem resulted after installing a certain software, there may be something wrong with its installation. Try doing a clean installation again. Uninstall the application then restart your system when asked. After booting, check your computer for any possible errors. Use a disk utility application to check the system. Install the software again then check if this fixes the problem.
