Driver for simulation games lan
A newly purchase simulation games lan card needs to install driver to play games. I have no CD for the driver. Which version of driver now available on internet for LAN?
There is a huge number of drivers on the internet for LAN. Â The one i would suggest is
Ethernet driver LAN adapter
or go for
Lan Driver nVidia Ver.8.62
i think this would solve your problem.
Hi Chesley Sielaff,
It would depend on what brand of the LAN card you have. When you buy an LAN card it must have a CD also which the driver can found there. But don’t worry my friend I have a solution for that just download software called Driverpack Solution. This software will find a driver for you. The only thing you to do is to install that driver. You can download it here https://drp.su/en. It’s 100% free.
Hope it helps. 🙂
If you want to play a simulation game on your computer that allows multi-player session on a local area network, you need to have a network card. Check first if your CPU is installed with a network card and what brand you are using. If you are using a laptop, consult your machine’s manual for the details on the network card.
If you are using an Intel network card, go to Intel Support Downloads for Network and I/O to download the driver for your network interface card. If you are using a D-Link network card, go to D-Link Support plus Downloads. Enter your network card model to download the latest driver specific for your network card. If your network adapter is Linksys, go to Linksys Support.
If you are using Netgear, go to Netgear Support. Enter your product model to go to your device.
