Driver for Spooling Device SEH-ISD300
I need help on installing printer driver? I’m using a spooling appliance. Do you have an idea about the spooling device SEH-ISD300? And is it possible to install more than one driver in a printer?
Dear Lewis,
Print job is main task in the network field. Inefficient spooling is causes of performance problem mean of traditional servers like NT, UNIX. They a very expensive and requires a lot of work and administration. The ISD300 has got rid out of these issues. It easily connect to your network appliance, it manage all printer job and handle all printers queues etc.
Installation of ISD300 device is very easy, simple and straightforward. Just connect it then it has automatically deleted all the devices and made the available prints in queues.
Regarding the installation of more than printer driver, yes you can install many printer drivers, but printer will detect only driver which you will plugged in with your PC.
Hope this tip will work.
