Drivers Application Usage Gives Out 0xd1 Error Code, Help Me With The Issue
Describe about the 0xd1 error? what is the cause of the error code and explain the methods to overcome this error message?
Dereferencing a bad pointer while executing at or above DISPATCH_LEVEL, accessing pageable data at or above DISPATCH_LEVEL, and executing pageable code at or above DISPATCH_LEVEL are the possible reasons behind the occurrence of the error code. It is a BSOD error that is caused by the corrupted system files. 0xd1 error is a driver error which indicates that a kernel-mode driver attempted to access pageable memory while the process IRQL that was too high. The solution to fix the 0xd1 error code are as follows:
Solution 1:
Fix the system
Step 1: Open the command prompt and run as administrator.
Step 2: Type “DISM.exe/Online/Cleanup-image/Restorehealth.”
Step 3: Insert media and type “DISM.exe/Online/Cleanup-image/Restorehealth/Source:C:RepairSourceWindows/LimitAccess.”
Solution 2:
Update the driver
Solution 3:
Restore the system
Step 1: Restart the system.
Step 2: Hold F8 button to see the operating system choice.
Step 3: Choose ‘Last Known Good Configuration’ from the Windows Advanced options.
