Hi Techyv Friends,
I am having Asus R 700 and recently I installed Windows 7 in that after that most of the drivers are missing in my system, Please suggest me on where to download entire driver set for Asus R 700 with Windows 7 as the OS.
Thanks in Advance,
Araceliariana
Drivers for Asus R 700 with Windows 7
Hello Araceliariana,
There are a couple of sites you can download the drivers you are in need of including this link. This site has different driver downloads for windows 7, 64bit including LAN drivers, VGA drivers, Audio drivers, chipset drivers, card reader, USB drivers, Utilities Bluetooth drivers and others. Go through and you will find what you need.
Hope this helps you.
