thor peiann
10 points
Posted on - 02/01/2013
Hi
I have recently bought Toshiba Satellite P845t-102. While deleting some files I think I had deleted its Bluetooth drivers. Can anyone help me find drivers of bluetooth for Toshiba Satellite P845t-102
Drivers of bluetooth for Toshiba Satellite P845t-102 ?
Hi Thor,
 To solve your problem, you must find your Drivers CD/DVD disc which came in your purchased laptop box. Once you find your drivers disc, insert it into a CD/DVD reader in your laptop. The drivers setup should start automatically now. Please search for "Bluetooth" column of the available drivers list. Once you find drivers regarding Bluetooth, install them. Once installed, restart your laptop and you should have a working Bluetooth.
Good luck to you.
Hello Thor,
I am sorry to hear that the drivers got deleted accidentally from your notebook. If you don't have the disks available to install the drivers, one alternative is to download it from Toshiba's Website.
Here is the link to download the drivers needed for your computer.
If you don't have internet connection, you can also try performing system restore on your computer and revert to the time wherein your computer still has the Bluetooth drivers installed.
