chris0125
Posted on - 09/27/2011
If I have hardware drivers already installed on my system how can I found out what the name of the drivers are ? [example if I have a geforce video card and lost the drivers that came with it, how can I found out?]
Drivers problem on my computer hardware!
Yes, if you have a hardware and you have lost its driver, you can find out by connecting the system to the internet and double click on your My Computer icon on your desktop. Go to properties; then select the Device manager option and go to the driver, which is not identified of which is not installed on your computer.
Now click on the update driver option in the main menu. It will give you two options, to install from a directory or automatically install from the Internet. Select that needed option and click next. It will search on the Internet and will find out the best and updated driver for your hardware.
Thanks
lee hung
75 points
Go to the start menu and click Control panel; you just see the programs and features and click that one or you can go to My Computer and then go to the drive ; double click when you see your drive name.
If you still don’t find the name of your drive, check the installer name on the CD and you can compare it with your installed software on your computer and try to check in the start menu, if it installed properly on your system and then if it installed correctly, go to the control panel and you can see the NVIDIA control or may the NVIDIA View Desktop.
