Drives Application has encountered problem in Windows XP
I am getting drive application error regularly. When I open the popup it needs to be closed. I am using Microsoft XP Professional. The error is, "Drives Application has encountered a problem and needs to close. We are sorry for the inconvenience." By clicking the error it need to be close. What should I do to fix it?
Answered By 10 points N/A #98141
You will need to run an application that will be able to find and fix any problem with the registry entries in the drivers, and I will recommend ccleaner for you.
  • Go to the internet and search for ccleaner application and install it on your computer.
  • Once the application has been installed, launch it, and then run the registry fix part to fix any problems with the registry entries on your computer.
You may also need to run system restore to undo any changes that you may have made that affected the system drives. To run system restore:
  • Go to start on your computer and then click on start.
  • Type system restore in the search field and then press enter.
  • The system restore window will open, and then you will choose a time before the problem started occurring and then restore the system.
  • Once the restore process is over, your system should be able to work properly.
Regards
Thompson Locker
