Droid 1 is not turning on showing some glitched logo at startup
When I turn on my Droid1, I get a glitched version of the Motorola boot logo in which the logo is off set. It is stuck there, I am unable to enter even recovery mode. If I leave it like that for a while, the screen goes black but the keys are still functioning and the backlight turns on, but there is nothing on the screen.
Please help me to get out of this problem.
Answered By 590495 points N/A #151950
Try restarting your phone again. Maybe it will work fine again after giving it another restart. If it doesn’t work, try turning off your phone then open its back cover then remove the battery. Keep the battery detached from the phone for a couple of minutes to completely discharge the phone of the battery’s charges. After a couple of minutes, attach the battery again then start the phone. See what happens.
If it still doesn’t work, try connecting the phone to the computer and then open its computer application. Try backing up your phone’s data using the phone’s software. After backing up everything from your phone, try restoring it to its factory settings to completely restore it just like the first time you bought it. Just install all your applications back after the restoration.
