Droid Mobile from HTC ?
Is it true HTC has launched new Droid mobile ? What is this mobile capable of ? What are the features in that mobile?
Yes you are correct. And some of the features of this phone are:
In terms of connectivity, this phone can let you call anyone in any place. This HTC Droid Incredible 2 will keep you connected. It also has a built-in DLNA Technology that has a bigger screen which is perfect for streaming videos, pictures and music direct from your mobile phone to your home entertainment system remotely. It has 4-inch LCD screen with SRS WOW and High Definition surround where you can truly enjoy your favorite music and movies. Turn your mobile phone into a hotspot with total of five Wi-Fi devices.
HTC has launched its new mobile which is the upgraded version of old Droid mobile. The latest droid mobile supports 4G technology. This is what it is capable of they have included more specification in to this also. This mobile supports both HTML and adobe flash. Droid has come with its new dual core processor of 1.2 GHz which allows using to experience multi tasking with no problem in handling the applications. This mobile has the OS of ICS which is Android 4.0. The specification of this mobile are similar to other smart phones difference is 4G and dual core processor. Overall its a good mobile.
The HTC DROID DNA is a discontinued 4G Smartphone operating on 2G, 3G, and 4G network bands using GSM, CDMA, HSPA, EVDO, and LTE technologies. It was unveiled to the public and released on November 2012 measuring 141 x 70.5 x 9.7 millimeters and weighing 141.7 grams. It uses micro-SIM card with Super LCD3 capacitive touchscreen display with 16M colors at 1080 x 1920 pixels screen resolution.
It supports multi-touch protected with Corning Gorilla Glass 2 with HTC Sense UI 4+. It runs on Android 4.1 Jelly Bean with planned upgrade to Android 4.2 Jelly Bean powered by Qualcomm APQ8064 Snapdragon S4 Pro chipset, 1.5 GHz Quad-Core Krait processor, and Adreno 320 GPU. It doesn’t support microSD. It runs on 2 GB RAM with 16 GB internal storage (11 GB user available).
The primary camera supports 8 megapixels with AF featuring LED flash and HDR and supports 1080p video recording at 30 fps with stereo sound rec. The secondary camera supports 2.1 megapixels and 1080p video recording at 30 fps.
It has 3.5-millimeter jack featuring active noise cancellation with dedicated mic; Wi-Fi 802.11 a/b/g/n with Wi-Fi Direct, DLNA, and hotspot support; Bluetooth 4.0 with A2DP and aptX support; GPS with A-GPS and GLONASS support; NFC; and microUSB 2.0 with MHL TV-out support. It doesn’t have FM radio. It has built-in accelerometer, gyro, proximity, and compass sensors. The pre-installed web browser supports HTML5.
It runs on non-removable Li-Ion 2020 mAh battery with standby time up to 353 hours and talk time up to 12 hours 40 minutes. It is available in black color.
