Droid stuck in a start up mode.
When i turn my droid pro on it shows the Motorola emblem, says"droid" shows the red eye and starts all over again. To turn it off i have to take the battery out.
Hope this helps.
Carl
This problem with restarting doesn’t only happen to mobile phones like the Motorola DROID but with computer operating systems as well like Microsoft Windows. This indicates a problem in the operating system itself. It is possible that one of the system files got corrupt. In Motorola, one possible way of fixing it is to start your phone in FastBoot mode to re-flash the handset’s ROM.
Before re-flashing your phone’s ROM, make sure it can start in FastBoot mode. To do this, turn off your phone. When the phone is completely off, press and hold the volume up, volume down, and power button simultaneously until your screen turns white. When your screen turns white, release the buttons. This should bring you to FastBoot. Try resetting your phone here then see if it works.
In case your phone doesn’t reset here and the problem continues, head down to Restore Motorola DROID from Bootloop with FastBoot Files and follow the guide carefully.
