Hi guys,
I want to know why my Dropbox is not synchronizing data itself? I have this problem since two days and I tried uninstalling Dropbox an the downloading again from Dropbox official link but still the problem is same. I on;t know what went wrong please tell me what to do now.
Dropbox data synchronization problems in Windows 8?
How are you? You should maintain the following steps to solve the problem.
Step 1 : Enter into the website : https://www.cloudhq.net/g_suite/.
Step 2 : Drag the Skydrive icon into the empty box on the left side.
Step 3 : By the use of your Google ID you can create your CloudHQ account.
Step 4 : Click on “Add Skydrive account” to authorize the Skydrive account. After authorization choose “top level” and click on “Select>>” option.
Step 5 : Finally Verify the options and click on “Synchronize Continuously”. That’s exactly it. Learn more.
Moreen Jamnelly.
