Dropping connection of Informatica repository service Windows 2003
When I start my Informatica repository service in Windows 2003, the connection suddenly drops. How do I fix this problem?
If your Informatica repository service connection disconnects soon after the connection is established then there can be a problem in the installation of Informatica service. You must make sure that you have fulfilled all the pre-requisites before installing Informatica. If you have missed something then fix it and re install the tool.
Secondly you should run the service from any local user account. This service will not work if you connect from an administrative user account.
Check the configuration settings. Make sure the database username you have provided exists in your database and has the required privileges. Also check the temporary server configuration and connection data.
If the problem persists then check your Event Viewer Log file and see if you can get more information to resolve this issue.
There are actually some loading problems associated with Informatica and they created a list for several known loading issues with their appropriate solutions. Below are some of the loading issues with Informatica and its possible remedy.
For the complete list of known load issues and their respective causes and solutions, visit Informatica and Loading Issues.
