Drupal vs Joomla vs WordPress
Hi Developers,
Drupal vs Joomla vs WordPress which is best and why?
Which is the best and which modules in them do you suggest to have to make the website look good.?
Thanks
Hi Developers,
Thanks
Actually we can not say that one of the better then the other, but each one has its own strong points that make it better in one area and make the other better in an other, so what you need for know is a simple comparison between different features between these three CMS (Content Management Systems) then you will understand what i mean;
wp : WordPress
D: Drupal
j: Joomla
History : wp 5/27/2003 D: 1/15/2001 j:9/16/2005
Total number of updates: wp 164 D: 77 j : 27
Number of plugins: wp : 14629 D:8039 j: 7609
Number of themes wp: 1392 D:885 j: Unknown
US monthly unique Visits : 50 million 55700 59600
this is an image that can help you decide what the best to use, but first as an advice if you are a beginner ,wordpress will fit you the most,
Notifications
