wali_a1
10 points
Posted on - 01/23/2013
Hi Everyone,
Now I am in a serious problem. When I want to browse from my PC, my PC became hang and a report show that, "DrWatson Postmortem Debugger" has encountered a problem and need to close etc.Â
I am using Norton Internet Security with 1 year subscription. I think my PC is infected and Norton can not delete them.Â
I also tried Kaspersky but No result.
 In this situation what can I do.
Wali
DrWatson Postmortem Debugger Crash Report
Dear Wali,
Dr. Watson is basically a windows error representative. Whenever there is any problem with the running programs in the explorer like Chrome, a file is generated by Dr. Watson. Windows Error reporting service also does the same functions which Dr. Watson does. So I am giving you the method to get rid of Dr. Watson error message.
Click Start
Run
Type regedit and click ok
HKEY_Local_Machinesoftwaremicrosoftwindows NTcurrent Version
Select AeDebug and double click and enter 0.
You will not get this error again.
