kwan jason
Posted on - 12/03/2011
What is the DSL Packages in Philippines for Residential and Business? Do i get a residential plan for my corporate?
Kwan Jason
lee hung
75 points
DSL Packages in Philippines /Business and Residential
Hi,Â
This are the DSL PackagesÂ
Residential Plan:
DSL 990 Monthly/Speed 384 kbps
  1995 Monthly/Speed 2 Mbps
  3000 Monthly/Speed 3 Mbps
  4000 Monthly/Speed 5 MbpsÂ
Business Plan:
  Plan 2199/Speed 1Mbps
  Plan 4000/Speed 3Mbps
  Plan 8000/Speed 8Mbps
  Plan 16,500/Speed 10 Mbps
CIR are 1/4 of the Plan speed.
With regards whether you can apply a residential plan into your business. Probably "yes". But depending on your strategy.Â
If you avail it before the construction of your building or office, then you can apply your business as a residential "youÂ
just tell during the inspection that this is just a room" so that it can declare as residential. The contractor willÂ
survey the location first before they install your internet. So it will be depending on your strategy on how you canÂ
approach. If you apply dsl make sure your area is capable because in Philippines not all areas are dsl capable compare toÂ
US.
Thanks,
Tony Stevenson
