Greetings,
I have migrated from Windows Vista to Windows 8 like a month ago. I am finding Windows 8 okay but for the last 2 days on startup I see an error from DSLR remote capture software. I installed it a couple of days ago. Any ideas on how to solve this?
DSLR Remote Pro for Windows
Unable to release shutter.
This may because the AF was unable to lock.
DSLR Remote Pro for Windows encountered an error
If you are seeing this error every time you start your computer, check again if the trial days are still ok and not yet exhausted. Normally, DSLR Remote Pro for Windows has only or gives only 15 days for its trial version. If you are using the trial version, it is important to check the remaining days since it has a short demo period.
Check when you first installed DSLR Remote Pro for Windows. If you still have remaining days, another possible reason why you receive this error is the version of the program since you are using the latest version of Microsoft Windows. The latest version of DSLR Remote Pro for Windows no longer supports older camera models like Canon EOS 20D, Canon EOS 5D, or Canon EOS 350D/Rebel XT if you are installing it on Windows Vista, Windows 7, or Windows 8.
For computers running on 32-bit Windows Vista, Windows 7, and Windows 8 with older camera models such as these, you need to install DSLR Remote Pro for Windows 2.4. These models also can’t be used on 64-bit versions of Windows Vista, Windows 7, and Windows 8. The latest version, DSLR Remote Pro for Windows 2.6.1, works with Windows XP, Windows Vista, Windows 7, and Windows 8.
This version supports these camera models:
Canon EOS-1D X
1Ds Mark III
1D Mark IV
7D​
6D​
5D Mark III​
5D Mark II
70D​
60D
50D
40D
30D
1100D/Rebel T3
1000D/Rebel XS
100D/Rebel SL1
700D/Rebel T5i
650D/Rebel T4i
600D/Rebel T3i
550D/Rebel T2i
500D/Rebel T1i
450D/Rebel XSi
400D/Rebel XTi
To download the latest version, visit DSLR Remote Pro for Windows 2.6.1. Besides Microsoft Windows, DSLR Remote Pro also works with Mac. DSLR Remote Pro for Mac supports Mac OS X 10.6 Snow Leopard, 10.7 Lion, and 10.8 Mountain Lion. You can download it from the same page.
