DSP Quattro: Temporary Files Exceed the MacOS Max File Length
I am attempting to export tracks on DSP Quattro for MFIT master. I have an album with a length of 1:30:42 and then I chose the File/Export Audio CD layout / Export CD – Tracks for my audio. However, I've got an error:
ERROR: the temporary or the destination files exceed the MacOS maximum file length. Please reduce the AudioCD Layout lenth or, if applicable, resample the audio files to 44.1 kHz before to export the AudioCD Layout image file.
How can I be able to fix this issue?
Answered By 10 points N/A #199777
I think this is a problem with respect to OS limitation. There is a 2-4 GB limit on the size on which export takes place provided the OS is formatted with FAT32 file system and most probably you will find this error. Ensure that the partition should be "Mac OS Extended" (aka HFS+). Alternatively, you may split your album into multiple smaller files preferably 60-70 min each and try export.
