DTH Setup box directly on the PC
Hello
Is  there a way to view TV Channels from the DTH set-top box directly on the PC? What are the requirements and are there any cables that need to be attached to the ports of the PC and connected to STB?
Thanks
Answered By 0 points N/A #108970
Of course you can do that, all about you need is to just buy a TV Tuner and you should follow the following simple steps:
connect VGA cable of your monitor to VGA port of your TV Tuner
connect cables at AV out (setup box) to AV in (Tv Tuner )
system is connected now you can enjoy transmission on your monitor using DTH set up box.
Direct to Home (DTH) is a technology related to satellite television broadcasting, the main edge of this technology is that it use wireless technology, programs are telecast direct to the consumer TV from satellite and consumer has no need of wires to be inserted. to enjoy DTH transmission one need only to basic things which are:
Dish Antenna
STB (set top box) is a receiver which translate the digital signal.
hope you will get what you want.
