masonj25
10 points
Posted on - 09/04/2011
I want to use Windows 7 & Ubuntu with the help of Dual boot, on the same computer. My computer specifications are c2d 2.8 GHz, with 2 GB ddr2 ram & 500 GB hard disk. I also have a 250 MB graphics card in it.
I was previously using windows 7 on my computer. Now I've installed Ubuntu & I'm trying to Dual Boot it using Easy BCD.
But when I try to "Add New Entry", Ubuntu is not available in the list.
Please tell me, how can I dual boot windows 7 & Ubuntu successfully.
Do I have to add a Manual Entry for it, how this can be done?
KevinN
5 points
Dual Boot Problem: Ubuntu & Windows 7
Hi Masonj25.
First of all, get EasyBCD 2.1 (the latest version).
Here's how to setup dual-boot using EasyBCD:
Boot into Windows and run EasyBCD.
Click on "Add Entry," select "Linux/BSD" tab and then set the Type as "GRUB2" from the drop-down list.
Click on the "BCD Deployment" button. Enable "Install the Windows Vista/7 Bootloader to the MBR".
Click on "Write MBR".
Reboot your PC. You will now see the Windows Boot Manager Screen with the option for Windows 7 and Ubuntu.
Optionally, you can edit grub from within Ubuntu so that you don't see the grub screen anymore after selecting Ubuntu from the Windows Boot Manager.
You can do it easily in this way for add boot menu of windows 7 with Ubuntu. You can add automatically at the time of windows installation. In this case you need to install windows 7 first then the Ubuntu. That means first you need to install windows 7 and then you need to install Ubuntu by this option “Install Ubuntu inside Windows”.
In these process windows 7 will automatically add its boot menu with Ubuntu.
If you already have Ubuntu and dual boot is not working then restart computer and Press [Windows]+[Break] to go towards boot setup menu. Then click the Advance System Setting. A task panel named “startup and recovery” will appear.
In here you can select your default operating system Windows 7 or Ubuntu.
