Dual Lan Card Simultaneous Enabled
220 points
Posted on - 06/18/2011
HI all,
We just setup a new additional LAN Card in our POS system. The old LAN Card was used for network connections for sales text file sending to Mall Admin which has a static IP address assigned by mall admin.
Now we are going to connect a DSL internet connection, but the problem is the ISP will be requiring us to connect to their DHCP server. Their solution is for us to install another LAN Card for the internet connection, but when 2 LAN cards are enabled we can only use the internet, but we can't connect and send sales file to Mall admin.
What we are doing is to disable the DSL LAN Card so we can send the text file. Our personnel sometimes forget to disable and sometimes they disable the wrong LAN card.
We want the 2 LAN card enabled and working simultaneously.
Thanks!
