Dual strike fx wireless gamepad for nfs run
I want to play the racing game nfs run with a gamepad. Which gamepad will be suitable for this game? I am thinking about dual strike FX wireless gamepad to play nfs run. Will it be a good one? Please suggest.
Answered By 5 points N/A #151768
Dear Cunningham,
Although the Sidewinder dual Shock FX is Microsoft branded gamepad, it does not allow as seamless gaming as the ps3 and xbox design gamepads that are available in the market.
Secondly, it is not enough value for money. My recommendation to you would be to get a Logitech gamepad. Preferably this one:
http://about.pricegrabber.com/search_getprod.php/masterid=819418998/search=Logitech+F710.
Select the best deal on it, order it and you'll enjoy need for speed the run a lot more than playing it on the keyboard.
Regards.
