The Dude’s web access configuration help
I've downloaded and installed MikroTik's The Dude network monitor management application. I am stuck at configuring for web access, though. When I surf the web it doesn't log and activity!
The Dude is a decent and good network utility. I have found  a configuration manual for Dude that will help you to solve your configuration problems. If you follow the step by step instruction given in the manual, you will configure your Dude network successfully, and you will have access to the web. Click the links below to get the manual:
http://wiki.mikrotik.com/wiki/Manual:The_Dude/Server_settings
http://mfile.narotama.ac.id/files/Nyoman%20Suryadipta/Dude%20Networking/Server%20Setting2.PDF
I hope I have helped you.
