Duplicate finder software deleting files
Hi there,
I recently downloaded Auslogics Duplicate file finder 3.4.1.0 and used the application to sort my media files, all was well until I decided to delete the multiple file to leave only one, when I started my computer today (HP Pavilion running on Windows 8.1 ) my media folders were empty, what could have gone wrong since I only deleted the duplicates only? How can I resolve this problem?
Answered By 15 points N/A #199604
Hi Azreil,
The 'Weeny Software' is used for deleting duplicate files from Windows 8.
Download the software from the Weeny official software
The features of this software are as follows:
1) It is easy to use for removing duplicate files
2) It finds duplicate files in drive of the system
3) It deletes duplicate files or moves them into an achieve present in the system
4) It has fast access and accurate duplicate comparison
The setup wizard for the software are as mentioned below:
1) Select the search drives from the system
2) Select the file types you want to delete
3) Set the search options for effective folder searches to delete the duplicate one
Answered By 45 points N/A #284481
Try to se the Duplicate Finder for Mac feature of Disk Drill to analyze your storage space for extra files that take up valuable space https://www.cleverfiles.com/find-duplicates-mac.html
Duplicate Finder can search internal and external drives to find and delete duplicate songs, videos, images, files, and documents.
