Duplicate printing of alphabets from Laser Color Printer
I have Laser Color printer HP 2600N in office. Since last 2 days, I am getting double image print. All words are making their image at back and sometimes on specific places having ink spots. Can some help me out what is the problem.
Answered By 590495 points N/A #91204
You have an alignment problem with your printer. Usually, when buying a brand new printer it is normally not yet aligned. If the printer is not properly aligned, the effects would be just like what you are seeing on all of your printouts. The image would appear as double image, some text will appear to be not clear in the printout, and you will have some ink spots on the paper as if the ink was dripping from the inside. The procedure on how to properly align the printer is included on the printer’s manual.
This problem is common to printers with scanner and copier.
