During ResourceBundleEditor Plugin I received the error message inside the Eclipse
Hi guys,
During ResourceBundleEditor plugin I received the error message inside the Eclipse on my Mac OS X 10.5.
It is indicating the error with StartOnFirstThread.
I searched possible source in the Eclipse but found nothing. If you have any idea regarding the error message, please help me to solve the issue.
Problem Occurred
Unhandled event loop exception
Can't start the AWT because java was started on the first thread. Make sure StartOnFirstThread is not specified in your application's Info.plist or on the command line
