I never really tried using my DVBViewer after some months of installing it. But now, everytime I am trying to launch my DVBViewer, an error is appearing. Following with the error message is a black screen. This happens after the recent upgrade of my Windows XP Pro to SP2. How can it be resolve?
DVBViewer Error
Impossible de trouver I'interface du filtre Audio/Video B2C2 MPEG2, error: 0x91000101 or Cannot locate B2C2 MPEG2 Filter Audi/Video Ctrl. Interface
(B2C2 Filter Error. This is probably caused by wrong tuner settings and/ or the trial to tune an encrypted channel)
DVBViewer Error 0x91000101: Cannot Locate B2C2 MPEG2
If you never used DVB Viewer after installing it months ago then it is more likely that it has expired. If you installed the trial version and it’s been months since it was installed then the trial days are already over. Normally, applications that are on trial version only give 30 days as its trial period.
I’ve never seen and used a program that provided more than 30 days of free use. If this is the case, since I think you have no use for it and you just install it for no reason mind as well uninstall it. It will never work this time because it is already expired unless you purchase a license for it.
In case you still want to use it, there is no use reinstalling it. The best way you can do is to download the latest version. Download DVB Viewer Pro 5.3.1. It supports Windows 2000, Windows XP, Windows Vista, Windows 7 x86 and x64, and Windows 8 x86 and x64. DVB Viewer Pro is a useful product if you want to enjoy digital content on your PC.
It uses a DVB card that allows you to view high quality TV images and will also allow you to listen to different podcasts with simplicity.
