I want to back up data on dvd to MP4 and ASF for apple iPod using blaze copy software but it is not working properly. It works up to 70% and then ends without any error. I have installed the latest version but no result. Please suggest what’s the problem? Any suggestion will be most appreciated.
DVD Backup problem with blaze dvd copy software
From where did you downloaded Blaze Video DVD Copy Software? Maybe you are using a corrupted or damaged software. Try to re-download it from the Blaze official website. The link is given below:
http://www.blazevideo.com/dvd-copy/
I can think of two problems: the first of them is corrupted installation of your software, and the second is that you don't have enough space. In order to make backups or to compress files your computer needs additional space on the hard drive because it makes temporary files. You should have at least 1 Gb of free space on your hard drive. I hope I helped. Regards.
