DVD lab shows error while making subtitles
I am working on a project making subtitles but now an error message appears every time I try to test any sub file. The error says “Error generating subtitle stream”. I also checked the timing and everything is correct but the error still remains. What should I do now to fix it ASAP? If you have any idea please share with me. I would be grateful to you. Thanks in advance.
DVD-lab
Error generating subtitle stream.
Start time of a subtitle> End time
Check the timing.
