In my system DVD writer is available.
I am trying to write one DVD with Nero, but I am receiving given error I reinstall window and Nero but this error is not removed.
Detail of Error:
DVD-WMV
Problem initializing Encoding Session
Error (0Xc00D 1B71): It was not possible to find a valid source plug-in for the specified source.
OK
I say thanks in advance for providing help.
DVD-WMV Problem initializing Encoding Session
Encoding error means there is a serious issue that have occurred in the computer and the program.
Encoding errors can sometimes due to a virus and a spyware, so as suggested you can try a removal tool that scans spyware, adware and other viruses in your computer, you can download it for free in the internet, try selecting a program that’s best suits your computer,
Once you have downloaded install it in your computer just follow the instruction in installation, once done run the program, and it will scan the major issues of your computer.
Your Nero burner is not capable of burning DVD-WMV formats.
I think the version of Nero that you have is somewhat incomplete.
I often experience that in most Nero installer CDs.
I also have a Nero burner, and I already stopped using it. You will think that it’s good because of the number of options inside the installed software.
But try using them and you will know that some of the options there only work on the newer version of Nero.
This means, those buttons are only there to add in the number of items in the options and really not working.
Your DVD-writer doesn’t have a problem. Replace the DVD-burning software you have.
Try CyberLink DVD Suite, it’s a combo of different CyberLink products including DVD-burning software.
I don’t know if there is still a trial for this but might as well try visiting the site for other trials:
