Hi there,
I have several combobox fusionchart on each sheet, and the problem is that the data in the charts are static. I need the data allocation in the combobox to be dynamic.
I therefore need a step-by-step guide on how to achieve dynamic allocation on the comboboxes.
Thank you
Dynamic combobox fusionchart allocation problem
Hello Nelson Carters
For creating Dynamic combo boxes, you can firstly take a look at this sample of filtered combo boxes which will give you brief idea of how to allocate data dynamically in the combo boxes.
It is a zip file and you can extract the content to any folder and open. It is a mdb file
Here is the link Sample Filtered Combo boxes
Hope this would help !!
Thanks
Bennie
