Dynamic CRM 4.0 has started an error…
Hi all,
One of our customer are getting the above mentioned error message when try to delete an order.
I have also tested his logon identification in several systems and it works very well.
He is using windows 7 as well as Norton antivirus installed on his PC.
Our CRM 4.0 server as well as rollup 16 has done.
I cleared each and every temp file from IE 7 browser > internet choices.
Then I disable windows fire wall, antivirus and all add INS from IE.
Still I get the same problem. Please help me to solve it.
Microsoft Dynamics CRM — Webpage Dialog
Microsoft Dynamics CRM has encountered an error.
Please tell Microsoft about this problem.
Microsoft Dynamics CRM has created an error report that you can send to help us improve
the product. Microsoft respects the privacy of your personal information.
View Privacy Statement
View the data that will be sent to Microsoft
Change error notification settings
Send Error Report Don't Send
Thanks a lot.
