I would like to ask a heat sink that will eliminate the overheating of my computer. Can you tell me anything about Thermalright Macho Heat Sink Family Round-Up? What is Thermalright? What do you mean by PWM-Fan? How does it work? What is the speed per minute? What are the materials used for the heat pipe? What are the connectors available for this? How much power does it require and consume? How much will it cost?
Dynamic Heat-Sink Ultimate Computer Cooling Solution
Hello Brenda!
For the last 2-3 years, Thermalright Macho became one of the most popular and most wanted heat-sink coolers in the market. Because of its cooling system that can support all desktop computers, the manufacturer puts everything on a bigger step. Thermalright has to most elite design. It is also the manufacturer’s name. Pulse-Width Modulation (PWM) is an operation that give signal to the fan to regulate more speed if the temperature is rising or vice versa. The speed of the fan ranges from 300 Rpm at its coolest and 1300 RPM for the fastest and sever temperature condition. The connector required to make it run is 4 Pin (PWM Fan connector). The amount MSRP 39.95. But outside market will even cost you more than $80.
