Hi Friends,
I am planning to create a static web page using the data stored in an Access database. Please provide the details regarding the creating of dynamic web builder with MS Access.
Thanks,
Cruz D Hatchell
Dynamic web builder with MS Access
The only process of creating dynamic web builder with MS Access is demonstrated in the following 11 steps below:-
1 > Open you database for MS Access.
2 > Open item that you wish to publish.
3 > Pull down the file menu and start the export process.
4 > Create a filename.
5 > Save the file.
6 > Open the ODBC Data Source Control Panel by double-clicking Administrative Tools and then again double-clicking the Data Sources (ODBC) icon.
7 > Add a new Data Source by clicking on the DSN tab at the top of the control panel dialog box. Then click the Add button to begin the process to configuring a new Data Source.
8 > Choose the Driver by choosing the appropriate Microsoft Access drive and then click finish
9 > Configure the Data Source by entering the Data Source Name
10 > Select the Database by clicking on the select button and then choosing the database and clicking on Ok button in the ODBC setup window.
11 > click the OK button in the Data Source Administration window at the very end.Â
