alvaldez
10 points
Posted on - 02/18/2012
Greetings to all members of the techyv community!
This is a really weird and frustrating problem. Just recently, I've been encountering an error whenever I try to launch Adobe After Effects CS5. After a fresh reboot, I tried to reinstall the program, but I keep on having the same error.
After effects error: Crash in progress. Last logged message was <4716><DynamicLink> <5> C:Program Files (x86)Common FilesAdobedynamiclinkCS5dynamiclinkmanager.exe
I really don't know what caused this problem. I need your help to solve this.
Thanks in advance.
DynamicLink error in AE CS5
Hi Alvaldez
The reason why you are getting this error is because you might have mishandled or shutdown your Adobe improperly (.exe file will be corrupted). This will cause a file to be corrupted or damage. Remove all the data for your adobe before reinstalling it. Because a save data will be left if you just uninstalled it using the control panel. If the same error comes out again get another installer for it and remember to delete first all the existing files for your adobe. (After effects is very sensitive with this issue. Improper or making a change in its files or adding ad ons on it will cause these error).
Thank you and Contact me for any question
That error with your Adobe After Effects indicates the program crashed. If this is a newly installed application, check that your computer meets the requirements. Adobe After Effects CS5 supports 64-bit Windows Vista (Home Premium, Business, Ultimate, or Enterprise edition) Service Pack 1 and Windows 7.
It requires 64-bit Intel Pentium 4 or equivalent AMD Athlon 64 or faster processor, 2 GB RAM, 3 GB free space, video card with OpenGL 2.0 support, and 1280 x 1024 minimum screen resolution. Apple QuickTime 7.6.2 is required to use QuickTime features. Verify that your machine meets the said requirements for Adobe After Effects CS5 to work properly.
If the problem continues, try to uninstall and reinstall the program. Download the free version of Revo Uninstaller and install it. Once installed, start Revo Uninstaller then select your Adobe After Effects among the applications and click “Uninstall”. Follow the normal uninstall process. When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds.
This removes everything the program created on your computer. When it is finished, close Revo Uninstaller then restart the computer. After booting, install Adobe After Effects back and see if it works.
